Date/Time: Sun, 19 May 2024 09:22:17 +0000
waiting to reconnect
View Count: 485
[2020-02-25 14:06:47] |
User359096 - Posts: 2 |
i'm receiving the message above. what should i do to resolve the issue
[2020-02-25 15:47:13] |
Most likely you have not entered some of the necessary information in the Data/Trade Service Settings for your selected service. Review the options on that page (File >> Data/Trade Service Settings) and ensure that everything is correct. If you still have a problem, then follow these instructions to get us your message log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-25 16:17:34] |
We see you are using Transact. So Transact must be having a server problem at the moment. There is nothing we can do from our side in regards to this.
