Date/Time: Sun, 19 May 2024 20:36:21 +0000
moving average study resizing the chart
View Count: 560
[2020-02-25 02:29:22] |
User465507 - Posts: 74 |
I'm using automatic scale range. If I add a moving average that is calculated over a fairly large time frame it may sometimes shift or resize the chart to fit the moving average onto the chart. Is there a way to prevent this? Just have the chart scale only according to the bar data but still show the study on the chart page?
[2020-02-25 10:27:42] |
Refer to: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
