Date/Time: Sun, 19 May 2024 14:54:38 +0000
Rolling cumululative delta
View Count: 585
[2020-02-25 00:50:30] |
User465507 - Posts: 74 |
Hi, is there any way to create something that tracks the cumulative delta for a custom time period, e.g., cumulative delta for past four hours or eight hours or a rolling 24 hours rolling cumulative delta rather than say a discrete cumulative delta for a given session?
[2020-02-25 09:28:28] |
You will want to use this study: Cumulative Delta Bars - Volume And you will want to set the Reset At Start of Trading Day input to No and then set the chart to load the specific time range that you require: Chart Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
