Date/Time: Fri, 02 Oct 2026 09:11:29 +0000
Rithmic Issue
View Count: 978
[2020-02-24 20:10:48]
User237090 - Posts: 14
Hi Support,
Still chasing this - - I brought up Rtrader from the icon and it populated the fields. I redid the password to make sure all fields were correct (it was greyed out) Didn't help the connection issue. The page didn't show up... So, I downloaded the new version and installed it with my credentials. It never really logged in properly.
Software version: 2054 64-bit | 2020-02-24 11:55:52.179
Enabled for: Advanced Features 2. | 2020-02-24 11:55:52.179
Enabled for: Sierra Chart Historical Data Service. | 2020-02-24 11:55:52.179
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-02-24 11:55:52.179
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-02-24 11:55:52.179
Current selected Data/Trading service: Rithmic Trading | 2020-02-24 11:55:52.180
Custom symbol settings values: enabled | 2020-02-24 11:55:52.180
Chart Update Interval: 500 | 2020-02-24 11:55:52.180
Intraday Data Storage Time Unit: 0 | 2020-02-24 11:55:52.180
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-02-24 11:55:52.180
2020-02-24 10:55:52 Local computer time | 2020-02-24 11:55:52.180
2020-02-24 17:55:52 Local computer time in UTC | 2020-02-24 11:55:52.180
2020-02-24 11:55:52 Local computer time in SC Time Zone | 2020-02-24 11:55:52.180
2020-02-24 15:42:15 Server time in UTC | 2020-02-24 11:55:52.180
Local computer UTC time and Server UTC time difference: 6 seconds. | 2020-02-24 11:55:52.180
Program path: C:\SierraChart\ | 2020-02-24 11:55:52.180
Data Files path: C:\SierraChart\Data\ | 2020-02-24 11:55:52.180
OS Version Number: 10.0 | 2020-02-24 11:55:52.180
Locale Setting: C | 2020-02-24 11:55:52.180
DLLs: EdgeTradingGroup.dll, EdgeTradingGroup_64.dll, ETOFSv3.DLL.dll, ETOFSv3_64.dll, JRS_SC.dll, JRS_SC_64.dll, JRS_UT.dll, MidJ_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VolumeBarsStackedByTick.dll, VRRangedetector_64.dll | 2020-02-24 11:55:52.180
Rithmic Trading | Port for executable: 57512 | 2020-02-24 11:56:14.328
Listening socket (1796). Port 57512 | Closed. | 2020-02-24 11:56:14.328
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-02-24 11:56:14.329
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57512. Current folder: C:\SierraChart\Rim | 2020-02-24 11:56:14.332
Rithmic Trading | Bridge process is running. | 2020-02-24 11:56:16.333
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57512 | 2020-02-24 11:56:16.333
DTC Client socket (1) | Creating socket. | 2020-02-24 11:56:16.333
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-02-24 11:56:16.333
Rithmic Trading | Connected to server. | 2020-02-24 11:56:16.334
Rithmic Trading | Starting socket receive thread. | 2020-02-24 11:56:16.334
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-02-24 11:56:16.334
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-02-24 11:56:16.336
Rithmic Trading | Sending logon request message. | 2020-02-24 11:56:16.336
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-02-24 11:56:16.338
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-02-24 11:56:16.342
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-02-24 11:56:16.342
Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2020-02-24 11:57:37.404
Rithmic Trading | Received logon response. | 2020-02-24 11:57:37.405
Rithmic Trading | Server Name: DTC Bridge. | 2020-02-24 11:57:37.405
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-02-24 11:57:37.405
Rithmic Trading | Logon error received from server | 2020-02-24 11:57:37.405
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-02-24 11:57:37.405
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-02-24 11:57:37.405
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-02-24 11:57:37.406
DTC Client socket (1) | CloseSocket call. | 2020-02-24 11:57:37.443
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-02-24 11:57:37.443
DTC Client socket (1) | Closed. | 2020-02-24 11:57:37.443
DTC Client socket (0) | CloseSocket call. | 2020-02-24 11:57:37.451
Rithmic Trading | Disconnected. | 2020-02-24 11:57:37.452
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-02-24 11:57:37.452
Rithmic Trading | Port for executable: 57541 | 2020-02-24 11:57:39.445
Listening socket (1584). Port 57541 | Closed. | 2020-02-24 11:57:39.445
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-02-24 11:57:39.447
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57541. Current folder: C:\SierraChart\Rim | 2020-02-24 11:57:39.450
Rithmic Trading | Bridge process is not running! | 2020-02-24 11:57:41.439
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57541 | 2020-02-24 11:57:41.439
DTC Client socket (1) | Creating socket. | 2020-02-24 11:57:41.439
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-02-24 11:57:41.439
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-02-24 11:57:43.443 *
DTC Client socket (1) | CloseSocket call. | 2020-02-24 11:57:43.443
DTC Client socket (1) | Closed. | 2020-02-24 11:57:43.443
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-02-24 11:57:43.443
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-02-24 11:57:43.443
DTC Client socket (0) | CloseSocket call. | 2020-02-24 11:57:43.457
Rithmic Trading | Disconnected. | 2020-02-24 11:57:43.457
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-02-24 11:57:43.457
Rithmic Trading | Port for executable: 57543 | 2020-02-24 11:57:45.462
Listening socket (1832). Port 57543 | Closed. | 2020-02-24 11:57:45.462
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-02-24 11:57:45.463
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57543. Current folder: C:\SierraChart\Rim | 2020-02-24 11:57:45.467
File >> Disconnect selected. | 2020-02-24 11:57:47.350
DTC Client socket (0) | CloseSocket call. | 2020-02-24 11:57:47.350
Rithmic Trading | Disconnected. | 2020-02-24 11:57:47.350
[2020-02-24 20:36:30]
We have discontinued all technical support for Rithmic and this post only confirms why (You are encountering this nondescriptive Rithmic OS error which should not even be happening). You will need to switch to this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
There is no reason to be using Rithmic, at all if you are doing live trading. The above service provides a much higher level quality of service at a lower cost.
Date Time Of Last Edit: 2020-02-24 20:44:28
[2020-02-24 23:27:51]
I thought I'd post to answer this issue (and provide some closure). Yes it was a Rithmic issue of sorts
in that I think it happened after a windows 10 update. This caused Defender to disallow Rtrader traffic
through the firewall and needed to "be allowed through".
Connected instantly after it was added to the allowed app list. This data sounds great. I'll more than
probably subscribe and I appreciate the link to this comparison/most asked question page. Thanks for your
patience and help today.
