Date/Time: Sun, 19 May 2024 17:52:11 +0000
Update not working
View Count: 621
[2020-02-24 17:57:51] |
User129295 - Posts: 3 |
I have a number bars chart set up and it is not updating to real time . Appreciate any help .
[2020-02-24 19:10:41] |
Tell us one of the symbols that is not real-time and are you at least receiving delayed data for the symbol?
[2020-02-25 19:10:53] |
Thank you for your timely response . I guess it was a temporary aberration . It is working fine today . When it was failing at one point I was getting delayed data but at a different time it was just where I opened it . Then no further data . Hope I didn't become a bother . . Thanks again . Steve |
[2020-02-25 19:14:31] |
Oh I was using forex pairs for symbols . Specifically at that time EURUSD and EURCHF
[2020-02-25 20:07:12] |
You should not have any problem with those symbols. Those are going to be real time when the markets are open. What problem are you having at this time with those symbols?
