Date/Time: Sun, 19 May 2024 14:46:25 +0000
No VWAP, 1SD, 2SD, 3SD line appears on Sierra Chart
View Count: 538
[2020-02-24 15:40:14] |
User986923 - Posts: 1 |
This morning, I open the Sierra Chart. Everything is OK except the VWAP, 1SD, 2SD and 3SD line are missing.
[2020-02-24 19:09:20] |
Make sure the VWAP study is still on the chart and that it is not Hidden. Refer to the following: Chart Studies: Adding/Modifying Chart Studies Chart Studies: Settings and Inputs Tab >> Hide Study If that does not resolve it, then make sure that each subgraph is set to a visible Draw Style. Refer to the following setting: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
