Date/Time: Sat, 18 May 2024 21:37:25 +0000
is there a way to arrange the Chart Trade Menu items?
View Count: 503
[2020-02-23 07:27:13] |
User658985 - Posts: 30 |
Ideally the bottom, or right side of the standard menu?
[2020-02-23 08:45:37] |
Refer to: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-24 05:40:32] |
User735389 - Posts: 188 |
Hi I meant this (please refer to pic), moving the trade menu items to the right side or bottom side of the main right-click menu
Date Time Of Last Edit: 2020-02-24 05:41:41
trade menu.png / V - Attached On 2020-02-24 05:40:12 UTC - Size: 43.21 KB - 206 views |
