Date/Time: Sat, 18 May 2024 19:28:54 +0000
Replay Control Panel mostly hidden
View Count: 705
[2020-02-22 16:27:37] |
User807026 - Posts: 86 |
I am trying to use the Replay function and when I click on the RPL button or go to Chart>>Replay Chart>>Replay Chart(Control Panel) the Control Panel Window shows at the very top of my monitor with only about the bottom 20% of the window showing. I can't drag it down to use it because the part that you drag a window by is not visible. Is there another way to get the Control Panel Window to show?
[2020-02-23 01:47:05] |
Refer to: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
