Date/Time: Sat, 18 May 2024 13:53:37 +0000
color bar based on slope study
View Count: 941
[2020-02-22 16:01:54] |
joer - Posts: 41 |
It would be helpful if this study allowed input of a slope value. So instead of coloring bars based on a simple positve or negative slope, color it above the input slope value or below negative the slope value. ie bars would be green if the slope was above .75 or red if below -.75 if the input slope value was set to .75. I know you people are very busy, but if/when possible, this would be a helpful enhancement to have. |
[2020-02-23 04:28:35] |
This is considered an old study which will not have any new development. You need to use the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition You can then reference the Study Angle study in the formula: Study Angle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
