Date/Time: Sun, 05 May 2024 17:12:54 +0000
Trade Chart Window Config Selection Synced but not Updated on Linked Charts
View Count: 449
[2020-02-22 08:45:10] |
BlakJak - Posts: 108 |
I noticed what may be a small error or oversight on the linked charts when the Trade Window Config selection is selected from the drop down list. The buttons are well synchronised, however the Trade Window Config on the drop down list at the top does not get changed on the linked charts. However, after a test I found it does act as if the drop down list had been changed. It seems that the list is just not updated when the list is already visible. This could lead to confusion. (Note I checked and if the Trade Window is not visible and is then made visible, the drop down list is correctly synced.) I have set up Shortcut Keys to switch Trade Window Configs and as I usually have multiple charts on the screen for the same symbol, I like to have the Trade Window linked so it does not matter which chart is current 'selected', it will still use the same config. Could you modify it so that not only buttons are synced, but also the drop down list when the Trade Window is visible? |
[2020-02-23 04:58:38] |
This is not something we are going to spend any time with now because it likely is an operating system level problem which eventually will get cleared up when we dispense with these Microsoft trash dialogs.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-23 05:04:39
[2020-02-23 23:29:54] |
This problem will be resolved in the next release. We do remember problems with selecting strings in this Microsoft list box, but that was already resolved. We just needed to add some code to cause it to update with Trade Window linking.
