Date/Time: Sat, 18 May 2024 13:37:51 +0000
pairs not showing up
View Count: 472
[2020-02-21 22:06:41] |
User786017 - Posts: 19 |
I just created charts for 31 different currency pairs. Half of them showed up. The other half did not. I'm not current updated with my service right now cause I'm not quite ready to start trading, but I'm not sure why (GBPUSD doesn't work for example) but EURUSD does when looking at the past
[2020-02-22 22:39:48] |
Your Sierra Chart account is expired. So there will not be any new data downloaded which does not already exist in the Sierra Chart Data folder. You will only be able to chart the existing historical data. ---- Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-22 22:59:29
