Date/Time: Sat, 18 May 2024 20:36:38 +0000
Linking charts
View Count: 1196
[2020-02-20 20:01:34] |
User531621 - Posts: 75 |
Hello! i use to be able to link a 4 tick with my 10 tick and have them scroll together as well as adding a study to one and it would automatically add it to my other chart. it no longer does the study part of it.. can you advise? Thank you
[2020-02-21 00:07:31] |
Ackin - Posts: 1865 |
(Chart >> Chart Settings >> Advanced Settings 2 menu) Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) |
[2020-02-22 08:23:38] |
Make sure that both charts have the same Link Number and that the link option for Studies is selected for both charts. Refer to the information here for Chart Linking: Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
