Date/Time: Thu, 02 May 2024 18:07:59 +0000
Order fill arrows not matching the candle
View Count: 568
[2020-02-19 16:25:25] |
User849476 - Posts: 17 |
Dear Team, Each time i take a position the order fill arrow isn't in sync with the canndle. You can see attached an exemple where i have circled the arrows in pint. Can you please tell me what's wrong ? Thanks |
for Sierra.png / V - Attached On 2020-02-19 16:24:16 UTC - Size: 178.66 KB - 218 views |
[2020-02-19 18:49:31] |
This is explained here: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities You will not have this problem when using this service: Sierra Chart / Trading Technologies Futures Order Routing Service Understand that we have discontinued support for Rithmic. After changing to the Sierra Chart order routing service, make sure that you have set Order Fills Start Date-Time both to 0/blank: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) This is explained in more detail here: Help With Daily Profit/Loss Value: Consistently Accurate Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-19 18:50:59
