Date/Time: Sun, 19 May 2024 07:51:02 +0000
User Contributed Studies_64.dll
View Count: 660
[2020-02-17 02:18:18] |
User311677 - Posts: 16 |
When I open Sierra_64 it says that Custom studies file does not exist, UserContributedStudies_64.dll Where can I find it or download it? If it does not exist, what can I do to keep the indicators I use running? |
[2020-02-17 03:17:53] |
Run the Sierra Chart installer again with Help >> Download Current Version and enable the "Install Optional Components" to get this file installed.
