Date/Time: Sat, 18 May 2024 21:05:23 +0000
Extended trial
View Count: 409
[2020-02-16 17:02:26] |
User560452 - Posts: 1 |
Hello, I had a sierra charts trial almost 1 year ago, right now my operative is diferent and my actual platform requires some indicators separatly, but sierra charts have that indicators all in just one platform I want to know if there is a posibility to take an extended trial to set up my charts and re-familiarise with SC Thank you |
[2020-02-17 00:32:50] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
