Date/Time: Sat, 18 May 2024 20:43:14 +0000
Gap in data for the ES after translating symbols
View Count: 539
[2020-02-14 21:30:38] |
mnill - Posts: 34 |
There is a gap in my data from 11/4/2019 to 12/12/2019 on my ES intraday charts. I am using continuous futures contract - date rule rollover setting. This occurred after translating my charts from SC Data - All Services to SC Futures Order Routing/Data, no other changes. Denali Data Feed. I have tried deleting and re-downloading data, tried volume based rollover setting, but can't seem to figure out how to fix this gap in data. I am using the current version of Sierra Charts. The gap is not present when using a non-continuous chart.
gap in data.PNG / V - Attached On 2020-02-14 21:27:56 UTC - Size: 54.92 KB - 201 views |
[2020-02-14 21:54:14] |
mnill - Posts: 34 |
Ok, so reverting to the previous version(2048) of Sierra Charts appears to have fixed the issue.
[2020-02-14 22:33:27] |
This is not version specific. You just need to follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
