Date/Time: Sun, 19 May 2024 06:11:11 +0000
Question about Sierra Chart DOM
View Count: 582
[2020-02-14 20:14:40] |
Jay Greenlees - Posts: 15 |
Hi the attached is a screen shot today from another Sierra Chart user's layout they have configured on the Sierra Chart DOM. Can you tell how to adjust the various settings in the Sierra Chart DOM to get the same layout Thanks |
Sierra Chart DOM.jpg / V - Attached On 2020-02-14 20:13:50 UTC - Size: 547.7 KB - 316 views |
[2020-02-14 21:29:35] |
User495158 - Posts: 106 |
You have to play with the settings. To arrange the columns use the trade dom customization menu. Adjust colors with the graphic settings. You also need to add volume by price study.
[2020-02-14 22:15:09] |
As stated by User495158 you have to make a number of adjustments. Here is where you will find information on how to make the changes. First, refer to the following for information on how to add the columns you want to the DOM, arrange them, and turn on the Volume Bars within each column: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Second, refer to the following for the beginning of the settings to change the colors of the DOM columns: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading and Chart DOM Colors, Line Styles, and Line Widths Third, refer to the following for general information on the Volume by Price study: Volume By Price Study Fourth, refer to this specific information for the Volume by Price study to change the coloring in the manner in the image: Volume By Price Study: Color Code Volume Bars Based on Percentage of POC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-15 23:44:49
[2020-02-15 23:44:57] |
The above post was missing a link and it now has been added: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
