Date/Time: Mon, 20 May 2024 14:58:23 +0000
Sierra charts issue connects to Rithmic but no data
View Count: 439
[2020-02-14 01:56:28] |
User839966 - Posts: 4 |
Sierra charts issue connects to Rithmic but no data , confirmed with broker , account enabled and am connected to rithmic 01 but no data can you please check on your side thx
[2020-02-14 03:30:05] |
This issue is now resolved assuming it is related to Symbol Settings. If you are missing symbols in File >> Find Symbol follow the procedure below: Follow the instructions here to update the Symbol Settings:
Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
