Date/Time: Mon, 20 May 2024 21:44:44 +0000
No symbols on Rithmic data
View Count: 955
[2020-02-13 20:53:09] |
User839966 - Posts: 4 |
Can connect to Rithmic data successfully but get no symbols. Why?
[2020-02-14 02:16:25] |
So you do not see any symbols listed in File >> Find Symbol? Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-14 02:46:53] |
Disregard the above message. We are working on the issue and we are aware of it.
[2020-02-14 03:29:40] |
This issue is now resolved. If you are missing symbols in File >> Find Symbol follow the procedure below: Follow the instructions here to update the Symbol Settings:
