Date/Time: Sat, 18 May 2024 20:19:45 +0000
Create an account (Sierra - OneUp Trader)
View Count: 599
[2020-02-12 21:18:58] |
User644366 - Posts: 1 |
I am currently on a trial account with Sierra How do I make sure I am getting a Sierra - OneUp Trader? How much is it? Anything else I should know? thx |
[2020-02-16 06:34:40] |
We apologize for the delay. Sierra Chart is the same no matter what service you are using. Pricing is found here: Description of Service Packages and Pricing OneUp Trader uses Rithmic and we do not provide technical support for that service, you will need to rely on OneUp Trader. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-16 06:39:27
