Date/Time: Mon, 20 May 2024 20:11:47 +0000
Custom calculated symbol doesn't show up when using "find symbol"
View Count: 450
[2020-02-12 15:17:52] |
User804299 - Posts: 3 |
I have added a custom calculated symbol, as category I used "specfic stocks". However when using "find symbol" the symbol doesn't show up under specfic stocks.
[2020-02-12 17:40:59] |
Did you enable the option for Use Custom Symbol Settings Values on the Symbol Settings window? Refer to the following information for this setting: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
