Date/Time: Mon, 20 May 2024 18:57:14 +0000
use excell for spreadsheet study
View Count: 544
[2020-02-12 09:15:50] |
User719206 - Posts: 92 |
Hello , did you remove the possibility to use excell to open a simple spreadsheet study ? I can 't find it in the input ?
[2020-02-12 15:21:18] |
ok ok i saw that you removed it , my problem is, I created a formula and the result is on one cell, this result change every time and i would like collect all of this result in a row. I mean that i each change of this result a fotmula ask to collect it in the cell down. I did'nt find a fonction in excell to do that, only an ABV code this is why i was interested to export my study on excell .
[2020-02-13 19:25:00] |
Look at using the Advanced Custom Study Interface and Language to accomplish what you need: Advanced Custom Study Interface and Language (ACSIL) ACSIL is able to interact with Sierra Chart spreadsheets to set numeric and string values into cells: sc.SetSheetCellAsDouble() See if you can implement a solution using ACSIL and the Spreadsheet Sheet interaction from ACSIL. We would think you would be able to. Until you develop an alternative solution continue to use an older version that has Excel support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-13 19:26:47
