Date/Time: Tue, 04 Nov 2025 10:44:39 +0000
Market Profile with 3 Sessions
View Count: 1548
[2020-01-29 15:24:22]
User513662 - Posts: 91
I was wondering whether it were possible to split the profile into 3 sessions (Asia, Europe, USA)? I have tried but I cannot see a way to do more than 2 sessions. Maybe there is an advanced way I am missing...?
Please see example attached.
Thank you in advance for your advice.
imageMP 3 Session.jpg / V - Attached On 2020-01-29 15:24:14 UTC - Size: 341.89 KB - 535 views
[2020-01-29 19:17:47]
Sierra_Chart Engineering - Posts: 21299
This is not supported.
[2020-07-13 23:44:42]
User656492 - Posts: 157
+1 for this request. 3 sessions would be most helpful. Also, perhaps you could suggest a way to cobble tyhis together?
[2020-07-14 00:09:40]
I have done this. I will send a chart book later. It pretty much does the job but each session time has to be the same due to it being based on the intraday candle. It’ll make more sense when I send the chart book...
[2021-07-16 14:33:49]
User695518 - Posts: 58
Hi User513662, Looks like it has been a little while since you posted this. Are you able to share your chartbook? I would like to see how you made the 3 sessions. Thanks.
[2021-07-16 16:15:28]
User365411 - Posts: 195
From rel 2187 we can set five intraday TPO sessions
Time Price Opportunity (TPO) Profile Charts: Number of Custom Intraday Sessions
[2021-07-16 18:28:23]
Yes this is now supported:
