Date/Time: Sat, 04 May 2024 19:23:18 +0000
New TICK calculation method April 2019 - retroactive in historical data?
View Count: 469
[2020-01-28 21:04:25] |
DabbaDo - Posts: 146 |
The change in the way you calculate the TICK market statistic, starting April 2019, seems like a big deal to me. Very nice! Sierra Chart Market Statistics: Market Statistics Calculation Change April 2019 Did you change historical data (is the change retroactive)? Or e.g. with TICK-SP will historical data in Mar 2019 be based on the old calculation method but Apr 2019 and later based on the new calculation method? Thanks. |
[2020-01-28 23:05:32] |
The historical data before that point in time is unchanged. It is not possible to change it. So it uses the older method which is certainly perfectly valid.
