Date/Time: Sat, 18 May 2024 12:03:00 +0000
Cannot connect
View Count: 404
[2020-01-28 12:07:33] |
User486666 - Posts: 7 |
Hi there I have problem to connect with my data connection error rithmic |
[2020-01-28 17:20:55] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed with File >> Connect to Data Feed. After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We see you are using Rithmic. We have discontinued technical support for Rithmic. If you are trading CME Group markets you need to move to this service: Sierra Chart / Trading Technologies Futures Order Routing Service If you are trading markets other than or in addition to CME markets, use this service: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 17:47:50
