Date/Time: Sat, 18 May 2024 11:37:07 +0000
connect
View Count: 457
[2020-01-28 12:05:46] |
User486666 - Posts: 7 |
Hi there I have problem to connect with my data I have come up. Erro connections
[2020-01-28 18:08:49] |
Sierra_Chart Engineering - Posts: 14423 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Select File >> Connect To Data Feed After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog ---- We have discontinued technical support for Rithmic. If you are trading CME Group markets you need to move to this service: Sierra Chart / Trading Technologies Futures Order Routing Service If you are trading markets other than or in addition to CME markets, use this service: CQG Trading Platform Service If you are doing simulated trading, then use: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
