Date/Time: Fri, 03 May 2024 10:16:54 +0000
Invalid TPO Profile merge parameters
View Count: 529
[2020-01-23 20:27:05] |
HinckleyBob - Posts: 45 |
The log provided this message when I attempted to collapse a Volume Profile Study, using the <rt-click> Merge Profile Begin and Merge Profile End menu. I reset the TPO study and attempted to collapse again, with the same message. I attempted to collapse the daily charts one at a time, with the same failure. The attached image shows the results. I kept this short, so if additional information is needed, I will happily provide it. But I didn't want to waste your time sending a bunch of unnecessary stuff. Please tell me what to try next, or what to send. Thank you, Bob |
TPO Study Error.pdf - Attached On 2020-01-23 20:22:07 UTC - Size: 731.74 KB - 259 views |
[2020-01-23 20:52:45] |
Sierra_Chart Engineering - Posts: 14189 |
Provide that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-23 22:09:08] |
I believe the chartbook you requested is attached. Thank you for the quick response.
Problem VP.Cht - Attached On 2020-01-23 22:08:45 UTC - Size: 44.92 KB - 213 views |
[2020-01-24 15:19:55] |
John - SC Support - Posts: 31334 |
The process of merging the profiles works fine for us in this Chartbook. The only thing we can think that you may be doing is selecting the same profile for both the Merge Profile Begin and the Merge Profile End points. Especially given what you show in the image you provided, where there is only the 1 profile in view. This will give us the same message that you received in your log. Refer to the information here regarding Merging and Splitting: Time Price Opportunity (TPO) Profile Charts: Splitting and Merging TPO Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
