Date/Time: Sat, 04 May 2024 13:01:37 +0000
High Volume, Low Range candles
View Count: 1165
[2020-01-23 20:26:47] |
User255679 - Posts: 1 |
Hello!! I would like to change the color of a candle when the candle has low range and high volume (absorption candle). I have already search, but I couldn't find anything related. It would be nice if someone could suggest me any studdie or any way to achieve it. Thank you so much in advance!! |
[2020-01-23 20:50:03] |
Ackin - Posts: 1865 |
Look at: Alert formula (Compare current bar with past X bars) |
[2020-01-23 20:50:16] |
Sierra_Chart Engineering - Posts: 14211 |
Refer to the following study: Color Bar Based on Alert Condition And refer to the following for creating Alerts: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
