Date/Time: Mon, 06 May 2024 20:11:36 +0000
Time on Charts
View Count: 472
[2020-01-23 20:05:34] |
Monserrate G - Posts: 27 |
I down loaded sierra charts on another computer. The problem I am having is that the time frame is out of sequence. For example on the 60 min charts instead of saying 7:00 am it is saying 7:15 am and the next hour it starts at 8:15 am. How do I correct this? Thank you
[2020-01-23 21:07:43] |
Sierra_Chart Engineering - Posts: 14244 |
Check your Session Times and the the option for New Bar at Session Start. Refer to the following: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
