Date/Time: Fri, 03 May 2024 09:42:23 +0000
Numbers Bars Last Price Color
View Count: 481
[2020-01-23 16:30:50] |
tdd2672 - Posts: 58 |
Is there an option to change the color of the last price in the Numbers Bars study? Presently I only see where it can be in bold but as the default color. I would to have the option to have this as a separate/contrasting color.
[2020-01-23 20:22:01] |
Sierra_Chart Engineering - Posts: 14189 |
At this time the only option is to Bold the data for the Last Trade Price.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-23 20:22:18
[2020-01-24 02:21:53] |
Will you consider adding the option?
[2020-01-24 15:08:01] |
John - SC Support - Posts: 31334 |
We take all suggestions and add it to our list of work. The reality is simply that we have a lot to do, so we cannot commit to any particular time frame for any particular suggestion.
