Date/Time: Sat, 04 May 2024 06:10:35 +0000
I can not find stock
View Count: 541
[2020-01-23 15:23:58] |
User904434 - Posts: 46 |
I use TWS and I want to trade STRABAG (which I see in TWS) stocks but when I put it into Sierra: Chart Settings/ Main Settings / Find……answer is "Symbol setting not found…." ? Should I change packege ?
[2020-01-23 22:12:20] |
Sierra_Chart Engineering - Posts: 14207 |
No, you do not need to change Packages. For Interactive Brokers, you will need to determine the appropriate symbol to use. Refer to the following: Interactive Brokers Symbols Also, be aware of the following Support related item: Changes to Interactive Brokers Position Reporting Symbols and Symbol Matching Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-23 22:19:41
