Date/Time: Fri, 03 May 2024 05:00:57 +0000
I signed up CBOT data today
View Count: 728
[2020-01-23 15:23:02] |
User811622 - Posts: 38 |
I signed up for CBOT data but, data is not showing up on my chart. I have CME already and that seems to work fine. Also, I have CQG through AMP. Please advice. |
[2020-01-23 16:38:04] |
Could you restart Sierra Chart. If you still have a problem with this follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
