Date/Time: Sat, 27 Apr 2024 06:10:02 +0000
running on parallels for mac returns error
View Count: 863
[2020-01-23 13:56:42] |
User851188 - Posts: 1 |
trying to run sierrachart on parallels for mac, and get the error "Md5 for file does not match. File: SierraChart.exe"
Screen Shot 2020-01-23 at 9.51.40 PM.png / V - Attached On 2020-01-23 13:56:12 UTC - Size: 10.82 KB - 191 views |
[2020-01-23 21:40:46] |
Sierra_Chart Engineering - Posts: 14107 |
Use the zip installer instead: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
