Date/Time: Sat, 04 May 2024 21:03:36 +0000
Chart header quantity
View Count: 1062
[2020-01-23 01:15:48] |
Kinobe - Posts: 86 |
hi Is it possible to retreive the quantity showed in the chart header in studies - see attached picture? |
quantity.jpg / V - Attached On 2020-01-23 01:14:23 UTC - Size: 854.01 KB - 277 views |
[2020-01-23 04:44:45] |
Yes. With this variable: sc.TradeWindowOrderQuantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-28 02:30:43] |
I do not find in the Chart Studies Window - see picture. Which study corresponds to sc.TradeWindowOrderQuantity ? |
chart studies windows.jpg / V - Attached On 2020-01-28 02:29:15 UTC - Size: 365.15 KB - 230 views |
[2020-01-28 03:52:23] |
There is no study. This is an ACSIL variable for custom programming.
[2020-01-28 23:55:45] |
please please please, could you add a study to get the trade windows quantity? please please please! |
[2020-01-29 04:11:42] |
And what should the study do exactly? Display the quantity as a study Subgraph? Or as a large number on the chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-29 04:12:18
[2020-01-30 00:51:46] |
I will use it with others studies subgraph to calculate the position average price if I add another position with the actual price and the quantity of the trade window. in other words, I will get a line for (1st position price x 1st quantity filled + actual price x trade quantity window)/(quantity filled + trade quantity window) |
[2020-02-06 12:01:11] |
hi do you consider to add this study in the chart study windows? thank you |
[2020-02-06 18:27:41] |
Yes we will get this done in the next few days.
