Date/Time: Sat, 04 May 2024 08:18:31 +0000
Historical/delayed data
View Count: 697
[2020-01-22 14:59:02] |
User170575 - Posts: 221 |
Hi---for mostly stocks---is there a free source to get historical/delayed data for Sierra? EOD data would be fine. Many thx, Cy |
[2020-01-22 16:44:40] |
Sierra_Chart Engineering - Posts: 14207 |
Yes. This is included with all Sierra Chart service packages: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-22 16:54:06] |
many thx----so with Ameritrade out is Interactive the best way to trade stocks?
[2020-01-22 16:56:18] |
Yes at this time and we are looking into a new service for trading stocks. We are looking at all possibilities including Fidelity and also a common order routing connection to Interactive Brokers.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-22 16:56:50
