Date/Time: Wed, 08 May 2024 04:18:48 +0000
fill color for parallel lines
View Count: 651
[2020-01-22 11:20:59] |
grantx - Posts: 244 |
Parallel rays and parallel lines do not have the option to fill with color. Is there a tool that allows this? Like the options for the rectangle tool - only angled. |
[2020-01-22 12:06:19] |
There is no way to fill between the lines if that is what you are asking about.
[2020-01-22 16:56:12] |
Are you able to implement it? An option to fill between the lines?
