Date/Time: Mon, 06 May 2024 09:04:18 +0000
[Programming Help] - SpreadSheet Formula for Close below then back above a level
View Count: 496
[2020-01-22 02:40:42] |
User355030 - Posts: 163 |
I'm looking for an example of a spreadsheet formula that would trigger an entry when a price bar closes below a level and then the next bar closes above the level.
[2020-01-22 20:13:44] |
Sawtooth - Posts: 3993 |
Try something like this: =AND(E4<ID1.SG1@4,E3>ID1.SG1@3) where ID1 is a moving average. This also works: =CROSSFROMBELOW(E3:E4,ID1.SG1@3:ID1.SG1@4) |
[2020-01-23 13:54:37] |
I need price to close below then above, will the example you provided work for that?
[2020-01-23 14:21:15] |
Yes. And you might want to set 'Signal Only On Bar Close (Columns K, M)' to Yes.
[2020-01-23 14:50:58] |
Thank you
