Date/Time: Tue, 07 May 2024 16:18:14 +0000
no Futures Spreads showing for CME/CBOT/NYMEX/COMEX (SC Exchange Data)
View Count: 568
[2020-01-21 19:44:23] |
T44 - Posts: 363 |
In the list of categories locate the Futures Spreads - CME/CBOT/NYMEX/COMEX (SC Exchange Data) category for CME/CBOT/NYMEX/COMEX spreads/strategies or the Futures Spreads - ICE (SC Exchange Data) category for ICE spreads/strategies, and press the + to expand that list.
This does not appear. I am not able to view / select the exchange supported spreads.
[2020-01-22 10:53:51] |
This does not make sense. There is definitely not any problem with this. What specifically is not appearing for you? Tell us the specific steps you are following.
[2020-01-23 21:16:04] |
T44 - Posts: 363 |
Hello, Steps are 1. Start Sierra Chart. 2. File | Find Symbol Here there are shown no spreads (no item Futures Spreads - CME/CBOT/NYMEX/COMEX). There is an "Other" which shows only an RBOB spread. I'd expect to see e.g. exchange listed calendar spreads in the CME products. Am I looking in the wrong place? |
10436-2020-01-23-2114.png / V - Attached On 2020-01-23 21:15:34 UTC - Size: 20.64 KB - 226 views |
[2020-01-27 20:33:09] |
Sierra_Chart Engineering - Posts: 14257 |
The way you get spreads in the case of the Sierra Chart order routing service is documented here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
