Date/Time: Sat, 27 Apr 2024 08:32:11 +0000
How to increase the subgraph text
View Count: 672
[2020-01-21 19:10:54] |
User774220 - Posts: 8 |
i am using the spreadsheet alerts to generate buy signals, i choose to use text as the subgraph options, but the text is so small. where is the setting to increase the font specifically for text that a subgraph generates?
[2020-01-21 21:09:40] |
Sierra_Chart Engineering - Posts: 14107 |
You need to use this Subgraph setting to change the size: Chart Studies: Subgraphs Tab >> Line Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-22 00:53:39] |
thanks, if i use either text or arrow for for example. it sits on the bottom of the bar.... i want to displace downwards to give some more space between signal and bar, but using displacement in subgraph only moves it right/left i dont see option to move downward... is that available? |
[2020-01-22 01:58:42] |
If you are using the Spreadsheet Study for this, then you can control the actual value of the Subgraph to position it. Also refer to: Spreadsheet Systems, Alerts and Automated Trading: Controlling the Location of Arrows or Subgraph Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
