Date/Time: Sun, 28 Apr 2024 03:45:30 +0000
Lost all my charts on main, when I updated an older instance of the software to 64 bit
View Count: 499
[2020-01-21 15:23:36] |
User180814 - Posts: 45 |
I had an older version/instance 32 bit of the software that I logged into and it updated to 64 bit and overwrote all of the charts in my core version of the software that was already installed as 64 bit. How can I go back and restore the older 64 bit version with all of my charts. This is a major issue I can be reached at 970-963-1819 if someone can reach out. Thanks, Marc
[2020-01-21 15:36:25] |
Yes we will call and have a look.
[2020-01-21 15:41:48] |
Thank you I am looking forward to the call 970-963-1819 Best Regards, Marc
[2020-01-21 16:10:42] |
When can I expect a call? I really appreciate it. 970-963-1819 I am sitting here waiting to resolve this issue.
[2020-01-21 16:41:15] |
User has been helped with remote assistance. They had Sierra Chart installed on their desktop. We moved it to the standard installation folder and got everything organized, and they are fine now. They are using Gain Capital . We are going to set up the Denali data feed for them now at no cost. As far as making a copy of your Sierra Chart installation to your laptop, refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-21 16:42:44] |
Do you require market depth data? We want to know what CME exchange to activate.
[2020-01-21 16:50:48] |
Yes I require market depth. For NQ ES CL, GC, RTY and all Micros Thanks, Marc
[2020-01-21 16:53:48] |
Check your email. The market data agreements have been sent there. You need to complete them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-21 16:53:53
[2020-01-21 17:26:08] |
Sierra Chart - Max - Posts: 5597 |
We have activated the data feed for you with the following exchange: Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts Sierra Chart Support |
