Date/Time: Fri, 03 May 2024 12:58:31 +0000
32 bit
View Count: 719
[2020-01-21 13:47:39] |
User36188 - Posts: 6 |
is there a version that I can use that supports 32 bit until I change to 64 bit
[2020-01-22 08:35:20] |
At this time all versions of Sierra Chart support the 32-bit and 64-bit version. So there has been no change at this point.
