Date/Time: Mon, 06 May 2024 22:42:13 +0000
Moving away from GAIN
View Count: 467
[2020-01-21 03:00:48] |
Mr.Arsov - Posts: 16 |
Hello, I'd like to move from GAIN. My broker is Cannon Trading. I tried to read as much as possible on the topic and it seems that your routing service isn't compatible with Cannon. I hope I'm mistaken and there is a way around that. Regards, |
[2020-01-21 06:01:44] |
It is supported by Cannon. We will be in contact with them for you.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-21 06:01:55
