Date/Time: Tue, 07 May 2024 05:03:26 +0000
UPDATE IN REAL TIME DATA
View Count: 539
[2020-01-20 16:40:10] |
User184582 - Posts: 14 |
Hello It seems that the chart no longer displays ticks by ticks quotes. I use the same data flow on another software and it works perfectly. I have the last version of sierra which is 2036. Can you help me with this issue? THANKS |
[2020-01-20 20:30:24] |
Announcement regarding Gain Capitol issue today and recommended solution: Announcement Regarding Gain Capital Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-21 08:02:14] |
Thank you for your response. Would it be possible to have a try for the real time exchange data feed? I cannot test denali because I trade on the Eurex thank you |
[2020-01-21 09:13:51] |
Yes you can. We will have that set up for a free trial later this afternoon. Both the data feed and EUREX will be free until the end of the month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
