Date/Time: Mon, 06 May 2024 00:04:09 +0000
Convert 32 bit dll to 64 bit
View Count: 641
[2020-01-20 15:24:24] |
User996502 - Posts: 28 |
hi, i have a dll that seems to work with sc 32 bit but it does not work with 64 bit version. is there a way i can convert this dll to make it work with 64 bit? when i look for the study, it does not show up in the custom study box. i have tried to add "_64" in the file name but same issue. |
[2020-01-20 15:25:26] |
Sierra Chart - Max - Posts: 5605 |
To convert the study to 64 bit, you need to have the source code for the custom study or studies and build the DLL again under the 64 bit version. For instructions, refer to How to Build an Advanced Custom Study from Source Code (.CPP file): How to Build an Advanced Custom Study from Source Code Sierra Chart Support Date Time Of Last Edit: 2020-01-20 15:25:48
