Date/Time: Thu, 02 May 2024 20:12:30 +0000
Price ladder on screen
View Count: 1592
[2020-01-19 18:12:34] |
User97684 - Posts: 136 |
Hi , Pls help - how to place a column with values/prices on screen? Many thanks, |
Attachment Deleted. Price_ladder_on_the_chart.png / V - Attached On 2020-01-19 18:12:16 UTC - Size: 221.15 KB - 699 views |
[2020-01-20 05:17:52] |
Not sure we are understanding the question because you are already making reference to the price ladder on the right side of the chart. If you want to see every price increment, then use the Scale Increment setting: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-20 12:26:15] |
Hi Thanks for quick response! Sorry i was a bit unclear - i am looking for an additional column with prices, inside the chart window period , closer to the numbers bars. Many thanks |
[2020-01-21 10:41:54] |
In the Numbers Bars study, set the option for Column 2 Numbers Bars Text to Price. Refer to the following for more information: Numbers Bars: Column # Numbers Bars Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
