Date/Time: Sat, 04 May 2024 00:43:24 +0000
Not able to erase drawn volume profile
View Count: 1101
[2020-01-18 23:01:45] |
User389151 - Posts: 37 |
Hi Sierra engineer, I'm not able to erase drawn volume profile after I leave it in chart a certain amount of time. It can be erased if it is not too long on chart. I think it's a bug. See attached. Hope you can fix, thanks. |
EraseVolumeProfile.JPG / V - Attached On 2020-01-18 23:00:59 UTC - Size: 266.58 KB - 315 views |
[2020-01-18 23:30:20] |
It is exceptionally unlikely there is any bug with this. Remove the study through the Analysis >> Studies window. If you have the problem again provide that chart by following these instructions and we will look: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-18 23:32:03
[2022-11-25 17:28:03] |
User286023 - Posts: 1 |
I had this happen after I changed some settings. What it did was list this as a different study under the analysis tab where it showed 2 different drawn profile studies in the list. To delete this just delete the volume profile with the changes you made. I know you probably figured this out after this time but if anyone else has this problem, easy solution.
[2023-05-16 17:42:34] |
hmtrader - Posts: 2 |
When the volume profile is added for a custom range (tools-> draw volume profile), sometimes it cannot be deleted on chart by right clicking the mouse as it cannot be selected. Most of the time, it can be deleted like other drawings by selecting through mouse and del. In such cases, as suggested above, it can be deleted by going to chart studies menu.
[2023-05-17 12:11:22] |
Sierra_Chart Engineering - Posts: 14207 |
Refer to: Volume By Price Study: Erasing Drawn Volume Profiles And: Volume By Price Study: Draw Volume Profile Tool Related Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
