Date/Time: Fri, 03 May 2024 08:33:34 +0000
Limit number of trades per bar
View Count: 642
[2020-01-17 11:23:54] |
User564539 - Posts: 27 |
How do i limit or control the number of trades per bar.
[2020-01-17 12:39:57] |
Ackin - Posts: 1865 |
Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) |
[2020-01-17 16:03:26] |
Do you mean limiting the number of trades in regards to automated trading?
[2020-01-17 17:54:21] |
Yes in terms of automated trading per bar like i can generate 2 or 3 trades only
[2020-01-18 05:50:38] |
Ok, something like this would require having your custom trading study counting the number of trades for the current bar by keeping that in a variable and also the current bar index. Would be best to use ACSIL for this: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-18 05:51:44
