Date/Time: Tue, 07 May 2024 21:45:18 +0000
How do you set the chart to automatic - scale range based on
View Count: 1130
[2020-01-16 22:48:42] |
Jay Greenlees - Posts: 15 |
How do you set the chart to automatic - scale range based on date range and changing price levels on the screen? For example if I am doing shorter time frame charts on ES (example 1 min, 2min 3 min or 5 min) anf the price is moving up and down quite a bit the chart screen currently is not auto-adjusting to keep the live price centered and if it moves up (or down) too much it goes where I cant see it anymore Thanks Jay |
[2020-01-29 03:01:12] |
Hi just following up on this since no reply
[2020-01-29 18:32:20] |
Sierra_Chart Engineering - Posts: 14261 |
Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Also, refer to the information in the following section. You will need to determine which Constant Range Scale Mode will work for what you want. Chart Scale and Scale Adjusting: Constant Range (Scale Range) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
