Date/Time: Thu, 02 May 2024 21:13:34 +0000
64 bit upgrade
View Count: 456
[2020-01-15 14:50:40] |
User430472 - Posts: 3 |
When I upgrade to the 64 bit platform do I need to completely uninstall the 32 bit software?
[2020-01-15 17:38:09] |
No, this is not true at all. You just simply run the 64-bit version using the shortcut on your desktop that has 64 in it. There is nothing to uninstall and there is nothing to install. The 64-bit version has existed for all users for years now.
