Date/Time: Tue, 07 May 2024 01:59:52 +0000
Extension Until Future Intersect Lines
View Count: 985
[2020-01-14 17:50:18] |
User236924 - Posts: 10 |
I sent support an image using this link: ... http://www.sierrachart.com/image.php?Image=1579023466644.png ... The pink and dark purple extension lines are non zero volume lines. I am trying to reference these lines to use them in alerts and strategies. I'm having difficulty. I'm looking for when there is a close above or below these lines. Sometimes it could take 3, 6, 10 bars or whatever. In my alert condition I actually wrote 100 separate conditions to go back 100 bars for both sides. Too much work and I didn't get desired results because it would reference old non zero lines that had already been closed above or below. ... Is there a way to do what I am seeking, even if I have to use ASCIL. Thanks |
[2020-01-14 18:58:51] |
You need to use ACSIL to access these lines. Refer to: sc.GetStudyLineUntilFutureIntersection() Also refer to: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-14 19:08:00] |
Thanks. So there's no way to do this using simple alerts? I'm an okay programmer but have no experience in ASCIL...
[2020-01-15 01:00:04] |
No, there is not.
